fusion ac clutch won't engage unless bypassed
Old 09-04-2017, 11:56 PM
ejskippy's Avatar
Default fusion ac clutch won't engage unless bypassed
My '12 fusion ac clutch doesn't engage unless the relay is bypassed.
I previously replaced the hvac control module. I just replaced the evap temp sensor and relay. Any ideas?
Old 09-05-2017, 05:47 AM
Part of the compressor control system uses high and low refrigerant pressure switches which are to protect the compressor if the pressure gets too high or the amount of refrigerant in the system is too low. The best thing to do is check the amount of refrigerant in the system with a set of A/C gauges. If the pressures are good then an electrical problem may exist.
jimbobhog
02-03-2016 04:28 PM
davetully
02-24-2013 05:51 AM
yayeer
06-12-2012 11:44 AM
helpmyford
04-07-2010 01:03 PM
Salvatorparadise
04-04-2007 02:13 AM
Quick Reply: fusion ac clutch won't engage unless bypassed
