FUSION HAS RIGHT REAR BANGING NOISE
:(This issue has been posted by at least 5 different Fusion owners. The same banging, clunking, rattle type noise happens when going over speed bumps, or pot holes in the road surface. Has anyone got a fix on this problem, or have an idea on what is causing thenoise. It is a "LOUD" banging type noise that can be heard very clearly. It sounds like the passenger rear wheel or suspension is loose, and ready to fall off the car.
Thank You - RAY |
RE: FUSION HAS RIGHT REAR BANGING NOISE
Is the spare tire loose?
This might be a fix for some owners! Out on: www.fordfusion.net there is an article/reply on resolving a Clunking noise on a Fusion related to passenger side. Check it out - it may be of some assistance to your problem.
Thank You - RAY |
