Fusion SE with sony system
Hello,
I have ford fusion 2011 se with sony system .Just bought aftermarket multimedia. I need help to do the harness I dont find wiring diagram for the radio connection.I took photo of the factory connection hoping somebody could help me. Dropbox - Mobile Uploads - Simplify your life |
Do you just need the connector pin out for the radio?
Do you need anything for the speakers. |
(Post 125241)
The radio does not directly connect to the speakers, there is a audio digital signal processor between them.
The radio is connected to the navigation system. Do you have directions from the aftermarket radio of what all wires you need to tap into. |
I uploaded the aftermarket harness to check.actually I need to know each wire connected in radio if you have the factory radio wiring diagram (amp wire steering control wire..etc).
https://www.dropbox.com/sh/ehvkb5kpj...pKKYeg22a?dl=0 |
Ok here is the connector views for all four audio control module(Radio) connectors.
The audio control module does not connect to the speakers but goes to the audio digital signal processing module which connects to the speakers. https://cimg5.ibsrv.net/gimg/www.for...cb083c0697.png https://cimg7.ibsrv.net/gimg/www.for...b20e9c6d3c.png https://cimg9.ibsrv.net/gimg/www.for...e67f6fb23a.png https://cimg0.ibsrv.net/gimg/www.for...f032503283.png |
Thank you, I understand know .I just bought
Axxess AXTC-FD1 to make the connection. |
