OBD on board diagnostics
Hello, I have a 2013 ford Fusion , today the OBD light came on it's an warning light for emission systems.Just wondering if anyone has had this light come on and what it took to fix it.I'm taking it in to get plug in but I'm curious.
Thanks |
If you are new to these things, most shops will charge to read any codes in the vehicle's computers. You can take it into one of the automotive parts suppliers and some of them will get the codes for you at no charge. Depending on what codes are found will determine what steps to take next. Sometimes a loose fuel cap can produce a code and cause the check engine lite to illuminate. I don't know for sure if your vehicle has a fuel tank cap to check , but that is just an example. If you already have an appointment with your shop, the decision is up to you.
