302
Old Mar 24, 2006 | 04:58 AM
tomotmho's Avatar
Default 302
I have an old 302 from a 71 stang and I wanna put 351C heads on it I heard from a friend that you need machine work to do it any ideas?
Old Mar 27, 2006 | 07:23 PM
Duffs302's Avatar
Old Mar 28, 2006 | 02:54 PM
Patrick's Avatar
Administrator
Default RE: 302
the guys at MF will most likely be able to tell you...
Old Apr 17, 2006 | 11:30 PM
82FBGT50's Avatar
Default RE: 302
do a search at mustangforums i remember a while back a guy had a article on it, i think one of the water holes was different from the windsor to the cleveland.
Old Apr 27, 2006 | 07:43 PM
stunner67's Avatar
Default RE: 302
I think you need a boss block to get the cleveland heads to work. Stick with 68-73 351 windsor heads. You will find that it all fits much better.
Old Jul 30, 2006 | 03:40 AM
ranger#2's Avatar
Default RE: 302
I think you'll need to machine new water passages to line up with "windsor" block,drill your head gasket too. If I remember, It calls for special intake and gaskets too. There used to a place called ? something River ? that handled that stuff.
I have thought about doing the same thing but depending what year 351c head your useing you may end up with a dog on the low end. That set up wont start working correctly til around 4000 rpm's due to the large valves and huge chambers and ports.
The aluminum after market heads for your 302 are awesome and you won't have compatability issues either.
Mustang and Ford just ran a feature on this not more than 5 or 6 months ago.
Good luck
bwbogott
Jan 23, 2011 03:17 PM
skip
Mar 13, 2008 10:46 PM
bundy351
May 6, 2005 03:21 PM
semperfi48103
Aug 30, 2004 02:28 AM
gt_ute_351
May 1, 2004 11:48 PM
