need help building a strocker motor
hello i need help! im trying to bulid a 351m stroker motor and id like to know what parts will make this happen. is it as easy as boring .30 over , a 400 crank and putting new heads on? i found this i might get, heres the link COMP Cams High Energy Cam and Lifter Kits K32-221-3 - Mobile SummitRacing.com will this stuff help me get what i want ? and if so what els do i need? how do i get all the numbers to match ? compression ratios and how much fule and air mixtures and heads go good with came? should i keep my 351m heads and have them built ? im full of questions !! lol
i spelled stroker wrong in the tittle. grate -__-
Don't go too confuse. You should have started what you want. If you go on thinking too much, then you just can't do it. The only thing to remember is just the correct formulation, air mixture and after it you start. Take first as first for your victory. I always do it whatever I'm got too much confuse.
