Boss 302
Does the Boss 302 motor have the same motor mount locations as other 302s.
I have a duece coupe with 87 truck 302 and want to bolt a Boss into it (after I find one) Thanks in advance |
Hello
did you find the "Boss" and install it? the motor mounts for all 302 should be the same... the block did change when Ford put a roller lifter in, at least that is what I read I think that was 1985. |
Are you talking about the 1969-1970 Boss motor or the SVO boss 302? I can tell you the SVO Boss 302 Block mounts the same as the 260-351 W block. Not sure about the older Boss.Roger
