1989 Ranger alternator questions
First, is there any way to tell what size (i.e., output in amperes) alternator I have? My truck has the 2.3L 4 cylinder and I was told those came with either a 40 amp or a 60 amp alternator. I also need to know if it has an internal or external regulator.
Second, because I have a power-hungry stereo system in the vehicle, I'd like to upgrade the positive alternator-to-battery charging wire so that there is less electrical resistance in the charging circuit. I want to leave the stock charging circuit intact, and supplement it with a run of heavy gauge wire direct from the alternator to the battery. The alternator has two plugs, with 3 wires going into each plug. Only two out of the 6 total wires look even remotely heavy enough to be the charging wire (about 10 gauge), and one is black with an orange stripe and the other is orange with a blue stripe.
Does anyone have any advice for how I should go about this? Would the procedure be different with an external regulator vs. an internal regulator? I was thinking that if the vehicle has an external regulator, and I ran wire directly from the alternator to the battery, it would bypass the regulator, and send unregulated voltage to the battery, which wouldn't be good.
It's been a while since my tech days. But the alternator is going to produce the same current and voltage reguardless of wire size. If you are relocating the battery further away I could see the need for larger gauge wire. If you find your discharging the battery hard you may want to try either a large capfor the to draw extra current from as needed, and/or a second batteryto provide the additionalstorage/capacity.
ORIGINAL: tomb1269
It is common practice in the car audio community to upgrade the charging circuit with heavy gauge wireas part of the so-called "big three" (Battery negative to chassis ground wire, chassis to engine block ground wire, alternator to battery positive wire).
bluzzer
Dec 13, 2018 08:56 AM
