2.9 auto tranny
Old Mar 29, 2006 | 06:54 PM
confedrebel89's Avatar
Default 2.9 auto tranny
hey guys. im having problems with my 89 ranger. i bought it from a guy for 100 bucks so im no that bad at a loss.... i hope... the tranny started off by slipping, so the guy "rebuilt the transmission" and now the sucker still slips and dont have reverse. dont know quite what to do... do i rebuild the tranny the right way, or just buy a new 1? please help!!! thank alot guys.
Old Apr 5, 2006 | 01:00 AM
drw0392's Avatar
Default RE: 2.9 auto tranny
I think that both would work, go with the most economical method.
Old May 19, 2006 | 01:49 PM
ranger_boy's Avatar
what kind of tranny is it i have a 2.9 tranny but it is for a 2x4 i would sale it for about $75.00 it is a 5 speed
Old May 19, 2006 | 09:33 PM
drw0392's Avatar
That sounds like a pretty good deal, I payed over 1K to have mine rebuilt and installed. I know, I know, I got ripped!
Old May 21, 2006 | 02:06 AM
Ramrod48's Avatar
around here those tranny's rebuilt go for , $1000 - $1400
Old May 30, 2006 | 06:32 PM
well, i picked up the truck and its a 88. its got a A4LD auto 4 speed overdrive. i got the tranny book with it, and it showed where they guy took out and replaced parts, and everything. he put that the thrust plate was broken but he still put the tranny back together. now i have to replace the thrust plate, clutch packs for low and high reverse and drive. someone told me that drive and reverse ran off the same pack of clutches but just geared lower???? dont know if thats right but i guess ill find out. if its cheaper than rebuilding this tranny i might put a manual in it. that might be another project in itself. but a truck with a straight body, strong motor, and good tires aint bad even if it dont gotta tranny ( but its the money you gotta put into the damn thing is what starts costing you.) what is cheaper? a rebuild or a used tranny i can use parts off of? thanks for any help. -Ryen-
Old May 30, 2006 | 06:42 PM
well, im thinkin if this tranny is gonna cost more then a manual just to rebuild, why spend the money if you dont know what the problem is right? how easy would it be to convert to manual form auto? i'd just have to put in a master cilinder, the lines, and the pedal, and different linkage right?
Old Jun 4, 2006 | 05:06 AM
drw0392's Avatar
How much is your time worth...?
I'd save my time and just buy a rebuilt auto.
After all of the misc. parts for the conversion I bet you'd end up spending just as much.
Old Jun 6, 2006 | 03:04 PM
hey, i tore the tranny apart and the forward clutch drum is shot and worthless. the seals went out in the pump which burned up my clutches. i priced a forward clutch hub, and a rebuild kit for new gaskets, seals, clutches and friction plates. i figure ill be spending about $175 to rebuild it again.
Old Jun 7, 2006 | 03:05 AM
drw0392's Avatar
It looks like rebel knows what he is doing this weekend. Good luck bro! (Don't forget your easy button!)[sm=signs003.gif]
harmission
Jun 21, 2024 05:19 PM
dave00beer
Dec 1, 2006 03:19 PM
blixx003
Aug 11, 2005 12:10 AM
