2000 ranger
If you look in your owner's manual, there is a section that tells you the blink code for the seatbelt. I cannot remember what it is under but mine was about halfway through the book. When you blink that code, it takes the annoying buzzer away. It worked on my 05 ranger, a 04 F-150, 04 F-250, etc. Mine was like turn the key on, set the e-brake, buckle and unbuckle the seatbelt three times, turn the lights on and off, buckle and unbuckle the seatbelt and it blinked the code. Every type is different so you need to look in your owner's manual. It works though and it doesn't mess with anything else and you don't have to keep a seatbelt plugged in in case you have to put yours own in a hurry if a cop is coming up to your window!!!!
CoyoteRoede
Apr 5, 2006 09:09 PM
