2000 Ranger Cruise Control Button Replacement
Old Mar 20, 2010 | 02:37 PM
gharmon's Avatar
Default 2000 Ranger Cruise Control Button Replacement
Replacement is straight forward. Disconnect battery. Remove two plastic plugs from lower parts of steering wheel cover. Remove two screws. Disconnect bag and lay aside. Take note of cruise control wiring layout, especially the secondary multi-wire cable on the right side that goes in and out of a bracket. Remove the four screws holding the two bag brackets. Remove the cruise control wiring harness. It will be necessary to carefully move the lower steeling wheel cover to move the wires. Reverse the process to install the new buttons. Now is also a good time to clean the battery connection and cable before reassembly. Final note......Dealer wants $128 for the part, Amazon's price was $52.42 with free shipping. Came in a Ford box.
Old Jun 25, 2010 | 04:33 AM
kurtdaniel's Avatar
ask for a discount..Cruise Control Button Replacement is just as easy as changing your Alternator..goodluck..
s_sam2001
May 7, 2013 11:45 AM
Fordman1949
May 20, 2011 03:52 PM
typhoon55
Nov 25, 2008 12:09 PM
tennesseesaturn
Nov 5, 2007 07:03 PM
AP
Jul 28, 2007 03:01 PM
