-   Ford Ranger (https://www.fordforum.com/forum/ford-ranger-16/)
-   -   2002 Power Window Problem (https://www.fordforum.com/forum/ford-ranger-16/2002-power-window-problem-6663/)
eoreillyfordranger Jan 9, 2007 07:46 PM
My '02 Ranger Edge driver side power window stop working.:(
Symptoms:
1) Driver side widows in the up position (closed)[:@]
2) Their is an audible click from the relay under the dash(next to the gas pedal) when the driver side power window button is pressed on the door.[:@]
3) The problem first appeared after the truck was warmed up, then it became permenant.[:'(]
I tried swapping around the relays from the passenger side (that ones working). I hate tobreak open the door panel to check the motor. Any suggeestion would help?:eek:
wheelsup68 Jan 9, 2007 11:17 PM
RE: 2002 Power Window Problem
Tap the body of the window motor with a hammer and see if it starts working again, if so you will need replacemet motor.
cobra79 Jan 10, 2007 02:35 PM
If the truck has some miles on it you may have a broken wire between the body and the door. I have run into this twice this month.
