2004 ranger 3.0 abs
Old Dec 2, 2008 | 08:37 PM
k26560's Avatar
Default 2004 ranger 3.0 abs
is there any way to run the abs self diagnosis without using a scanner? I just bought the truck and the brake pedal goes to the floor. the resivour is full and I don't see any leaks.
Old Dec 3, 2008 | 04:34 PM
techford's Avatar
Default RE: 2004 ranger 3.0 abs
Hi, there is no way to get the code without a scanner. You might to deeply check your braking system. Make sure there is no air in the system, that the wheel cylinders are working properly, springs are good, slide pins are not seize or calipers.
Nic.
DonF150
Feb 24, 2012 03:13 AM
Use Common Sense
Aug 14, 2010 10:07 PM
Hutch64
May 31, 2007 09:21 PM
veivoo
Dec 9, 2005 09:24 PM
veivoo
Dec 9, 2005 07:49 AM
