an 88 that dies when it wants to
Old Sep 18, 2005 | 12:34 PM
maineman's Avatar
Default an 88 that dies when it wants to
i have an 88 ranger with the 2.3 that just dies anytime it wants to.i have changed the tank fuel pump,control module,and relays.still to no success.cranks over fine but the fuel pump does not engage.leave it sitting for a period of time and it fires right up like nothing is wrong with it.
anyone have any ideas?
Old Sep 19, 2005 | 05:13 PM
cctxfish's Avatar
Default RE: an 88 that dies when it wants to
Are you loosing fuel or ignition?
Old Sep 21, 2005 | 09:36 PM
maineman's Avatar
not ignition the spark is just fine.
when i try restarting. the fuel pump in the tank will not engage.it is a new fuel pump
Old Sep 22, 2005 | 02:58 PM
cctxfish's Avatar
Have you tried a new fuel pump relay?
Old Sep 25, 2005 | 08:07 PM
maineman's Avatar
yes and dont know wherelse to turn
Old Sep 26, 2005 | 01:12 PM
josser's Avatar
does your truck have an emergency shut off valve some where? besides the fuel relay did you check for a burnt fuse!
Old Sep 27, 2005 | 08:48 AM
maineman's Avatar
i have checked the fuses,and it has the inertia switch that it not poped when the problem is present. i wonder if it could be the switch and if so how i would check that when the it happens periodically?ill assume check it when the pump will not engage?
Old Sep 27, 2005 | 04:14 PM
cctxfish's Avatar
Truck has 2 fuel pumps, T/S with test light and multi meter
http://www.autozone.com/servlet/UiBr...3d800f9461.jsp
Old Apr 14, 2006 | 10:15 PM
maineman's Avatar
i started meesing with the ranger the other day and got it running.shut the truck off and it would not start.i go and borrow some jack stands so i could put it up and drop the tank to check pump again!!.well,well,it starts right up again.played that game for a wile.finally got it to where it wouldnt die so i take it for a ride.6 miles up the road it DIES.sat there for an hour thinking in circles,i look over to the passenger floor and see the inertia switch wires and say the hell with it and cut them.wired it together and turned the key.it fired right up and havent had a problem since!
Old Apr 15, 2006 | 12:10 AM
CoyoteRoede's Avatar
hahahahahah sometimes its the simplest things that we dont think of. glad to hear that its running again.
