93' Hydraulic clutch problem
The hydraulic line at slave cylinder will not stay connected. I make the connection,give it a tug and it seems fine,when I press clutch pedal the line pops loose.
The connector looks slightly worn but before I spend the cash on a new line I thought I would ask if anyone knows if this is more of a problem with the slave cylinder malfunctioning. Could the slave be sticking and causing the line to pop loose? Any help would be appreciated. |
Hydraulic lines can withstand quite a bit of pressure. Suggest you get a new line with a good connector.
Thanks hanky,I feel a bit better spending the money now, from what I have seen on these boards I respect your opinion very much.
Thank you for your confidence. Sometimes I just get lucky !
