-   Ford Ranger (https://www.fordforum.com/forum/ford-ranger-16/)
-   -   98 Ranger 3.0 Engine high RPM's when warm (https://www.fordforum.com/forum/ford-ranger-16/98-ranger-3-0-engine-high-rpms-when-warm-1113/)
planefella Jun 19, 2005 12:34 PM
When my 3.0 Liter 98 Ranger warms up I have an intermittent problem with high RPM"S - I'll pull up to stop or be in traffic and the engine goes to about 3000-3300 RPMS' - sometimes I can get it to slow by feathering the clutch a few times and then it will drop back to idle in nuetral or with the clutch in - but this is hit or miss? I suspect some sort of sensor - help please!
DangerRanger Jun 19, 2005 09:20 PM
RE: 98 Ranger 3.0 Engine high RPM's when warm
Was the battery disconnected recently?
hockeyhitman69 Jun 19, 2005 09:32 PM
sounds like iac valve (idle air control sticking)
josser Jun 21, 2005 08:24 PM
i have a 97 that did the same thing for sometime all i did was hit the gas pedal very hard and it quit doing it.
planefella Jun 28, 2005 05:11 PM
Yes - I had a new starter put in so the battery was disconnected - but it was doing this even before - what's your thought?
josser Jul 2, 2005 11:44 PM
i'm with hockey, check the IAC valve and also the TPS (throttle positioning sensor) to make sure they are operating within spec volts.
Ramrod48 Jul 15, 2005 12:58 AM
yeppers if I had to bet money I say IAC, take the 2 blots off unplug the wire get you some carb. cleaner , and down inside the holes get filled with blowby jest keep rinsing it out till its clean , an carefully see if the plunger will move up an down. If i remember rite it has a one inch stroke that provides the computer with over 230 diff settings !!!!,, I have seen them so clogged up the the holes in the throttle plate where closed off,, they are basicly a metered vaccum leak
