99 Ranger power locks stay locked
Hello.
Power lock on driver side stays locked. Even if I unlock with key it will go back down. FOB only unlocks passenger side. I have to hold key to unlock position while opening the door. When I let go of the key it locks. Passenger side no issue with door switch or FOB. I had the actuator replaced couple weeks ago because they stopped working. It worked fine until the other day. I think it’s draining battery too. It’s sluggish to start but then fine right after running. But will get sluggish after a short time. But it may just be the battery. any suggestions for the locks? |
Somebody is going to have to go inside that door and see what is happening.
One that is known , measures can be taken to correct. |
