Check Engine Light Ford Ranger
Old Oct 18, 2009 | 12:03 PM
PJTm's Avatar
Default Check Engine Light Ford Ranger
Own a 1999 Ford Ranger How do I shut off the check engine light?
Old Jan 12, 2011 | 10:23 AM
88 Turbo's Avatar
There are several way you can clear the check engine light in these trucks. First, you could have a scan tool connected to the truck to see what the trouble code is and have the problem fixed. Once the problem is fixed you can have the code cleared which will make the light go out. Second, you can disconnect the battery for about 5 min. and reset the computer, however if the problem has not been corrected, the check engine light will come back on, once the computer picks up on the problem again. Hope this was helpful.
Newman271
Mar 21, 2021 12:54 AM
sky81
Jan 27, 2013 11:27 AM
allensimpson
Jan 10, 2008 09:40 PM
dwight
Oct 16, 2007 10:24 AM
kurt k
Apr 1, 2007 08:35 PM
