clutch problems!!
i have a 1983 ford ranger and i recently replaced the clutch throwout berring pressure plate,now i wont go into gear with truck running it grinds,if i shut it off and put it in gear and start it it starts engaging even with the peddle to the floor.there is no bleeder on the slave cylinder what do i do?and the fluid is full?
Are you positive you have the clutch disc installed correctly ? If backwards they don't release too good if at all.
You might try to loosen the hydraulic line to the slave cyl at the clutch master cyl and allow the air in the line to rise and come out. |
That's weird. My 1983 Ranger 2.0 w/4 speed had a bleeder valve on the top of its slave cylinder that I used when I replaced the clutch and installed new fluid.
