Crank shaft Pully nut Size
I'm replacing the timing belt in my 1992 Ranger 2.3L XLT and what to know the bolt size on the Crank Shaft pulley.
Also is it easier to remove the radiator to get to the crank shaft? |
Geez
Stick a socket in there till you get the correct one.
With such limited space rad removal could be an asset. |
I'm collecting tools, so I have everything ready. I will look tonight to see if I can get to the bolt. :) smile
