Door ajar!!! NO it's NOT!!!
My interior Dome light and door ajar light stay on. I have shut the doors numerous times but still the light stays on. It has been doing this for about 2 months now. Any ideas?
RE: Door ajar!!! NO it's NOT!!!
simple fix, either change the interior door switch on the doors or spray some wd40 on the door latch mechanism, the switch is combined with the latch and it gets stuck, specially in the winter time.
Replacing the sensor in the door can be a pain in the a$$, if you're in a pinch you could always just pull the fuse till you get some time to take further action. I too have heard that spraying the jam's latching mechanism with something like WD40, or putting some graphite in there will also help.
go get it scanned and replace the door switch.....wd 40 is a shorterm fix if you know which door it is
I had been having this same problem since I got my ranger a few months ago. Just got some WD40 and worked the door for a few minutes (spray open close) that door ajar light turned right off.
WOOHOO! |
anyone know where the fuse is for the dome light? mine doesnt come on at all door open or not. i cant even turn it on.
pull fuse thats what they make a mag lite for
