First post please help a newbie
Old Feb 11, 2008 | 12:04 AM
  #11
Bigboyky's Avatar
Default RE: First post please help a newbie
Well heres an update. My son got the crankshaft sensor on and everything put back together. Still won't start. Any more ideas? Could a bad ground cause this but still allow the motor to turn over? I/heare at a loss on this. Would like somemore suggestions. Thanks
Old Feb 11, 2008 | 03:55 PM
  #12
tomb1269's Avatar
Have you tried swapping the ECM with the one from the donor truck? If you have access to a professional diagnostic unit it should be able to static test, as I assume you have disconnected the battery by now and lost the original error code?? If not get a reader on it and try to get the code.
Old Feb 11, 2008 | 09:20 PM
  #13
Bigboyky's Avatar
no he hasn't tried the swap.... Can you just swap those over? I know you can't with a newer one unless you can getthe dealer to flash it for you which they won't.
Old Feb 13, 2008 | 05:21 PM
  #14
Bigboyky's Avatar
Still needng help on this one.
Old Feb 17, 2008 | 10:41 PM
  #15
Bigboyky's Avatar
I've been out of town the last couple days. Andwe are still lost on this. My son has swapped over the Crankshaft sensor. And we still aren't getting anything. What gives the coils the signal to senda spark? Could the ignition module be bad? Is there a relay somewhere? I (at this point it's me) need some help here! Any and all ideas welcome! I know somwone on here can give me some direction..... Thanks!
Old Feb 19, 2008 | 04:05 AM
  #16
FordinmyVeins's Avatar
to my knowledge the computer or ECM tells the coils to send spark to the plugs. but also as everyone else has stated, if its not properly grounded it wouldn't work either. is your donor truck the same? if its the same (engine type and whatnot) it should be a straight swap. assuming they are the same ignition of course.
Old Feb 19, 2008 | 05:23 PM
  #17
Bigboyky's Avatar
Yes the donor truck is the same. We did swap the EECthem out but still nothing. This is why we are having so much of an issue. The coils, the crankshaft sensor, the ignition module, plugs & wires,changed over the relays, battery cables cause his were worn. It's hard for me to believe that a wire just broke while driving.
Old Feb 20, 2008 | 11:58 PM
  #18
Use Common Sense's Avatar
I didn't read if the ICM was replaced. The Ignition Control Module is what the coils plug into. The ICM is what tells the coild to fire. The ICM needs to have a good ground/ground surface.
Old Feb 22, 2008 | 09:41 PM
  #19
sumrbeachbum778's Avatar
I know this sounds really stupid and you have probably done this but there is a reset buttom on all rangers under the glove compartment in the passenger seat. A few months ago my boyfriend hit it and didnt realize it. We changd the fuel filter, nothing, fuel pump, nothing. Then had it towed to the shop and all they did was press the button. We spent alot of money for nothing but he thought he had tried the reset and obviously he didnt. Just a thought.
vaultdweller
Aug 12, 2017 03:15 AM
2ron2dude
Feb 7, 2008 10:07 AM
vizion autosport
Apr 13, 2007 02:15 AM
M925
Feb 10, 2006 01:33 AM
