Ford Ranger OBDI or OBDII
1 Attachment(s)
hi guys, i have a ford ranger and i want to invest in a diagnostic tool, however im not sure if its obd1 or obd2...attached is a pic of the port.
What year is the vehicle?
(Post 78932)
File:Ford Ranger front 20080419.jpg - Wikipedia, the free encyclopedia |
I believe just about all OBDII systems have an oxygen sensor after the converter where none of the OBDI systems I have seen have that feature.
Since the vehicle has a Mazda type set-up I would suggest you check with a Mazda dealer service dept. and they should be better able to suggest the better scan tool. It does appear to have the OBDII system. |
thanks bro
if its 1996 or newer it will be obd2 which has a 16pin connector. The location of the connector link will be in the passenger compartment. obd2 mandated standardization of the connector and location of the connector.
The picture in not of a obd2 connector. What is the tenth character of the vin? what ever scan tool you get; get one that can display live data. A code reader can't, a scan tool can. Do you want something that can display abs and airbag dtc, body and underfined codes or just powertrain codes? I bought a launch c-readerVI and i am very pleased with it. |
