Fuel problems
I have a 90 4x4 ranger. The truck was running fine and then quit like you switched it off. Changed the fuel pump, filter, relay, and checked firing. Truck will start but will only run for a few seconds. Any suggestions on what to do next?
RE: Fuel problems
Check for "GREEN" grounds starting at the battery and working your way back. Mainly check for a faulty ground on the lead going towards the CPU.
