What did I do wrong? P1443
Old 10-25-2006, 11:03 PM
apollo's Avatar
Default What did I do wrong? P1443
Okay, so my CEL came on with the typical P1443 code on my '95 2.3 5speed 4cyl with 135k on it. I replaced the PCV valve and the Cannister valve assembly (the whole assemby: Ford Part # F57Z-9C987-AB). MY CEL is still on! I took it for about a 10 mile drive and it won't shut off! The only thing I can think of what that I didn't disconnect the negative battery cable when replacing the parts. Could that have something to do with it? HELP!!!
Thanks!
Dave
Old 10-25-2006, 11:40 PM
Default RE: What did I do wrong? P1443
DTC P1443 indicates an incorrect Evaporative System Purge Control Valve flow. This can be caused by a clogged, disconnected or broken vacuum line between the EVAP Canister Purge valve and the intake manifold as well as a bad EVAP Canister Purge valve itself..
Is the gas cap on correctly?
parfect
08-10-2010 06:25 PM
Quichang
05-06-2009 07:13 AM
americanmade929
03-19-2008 07:57 AM
dbjones
05-20-2007 09:07 PM
Apcsox
05-23-2006 09:43 PM
Quick Reply: What did I do wrong? P1443
