Leaking Gas
I'm leaking gas when I fill up at the gas station. I notice that it leaks when I fill to fast, or fill all the way. I never top off, I let it run till full. Then I notice about half a gallon or so of gas leaking off the side of the talk on to the ground! Possible cracked fillertube? Any Ideas?
RE: Leaking Gas
if its an old ranger it could be the tank or the filter tube or the seal around the fuel pump but 2 things for you, either get under and replace somethings or on't fill it up til its full.
RE: Leaking Gas
If you can figure out where its leaking coat it in seal all.
I sealed my Radiator on my F150 with it, its aweseome stuff. later, Dustin |
