lubricating intermediate steering shaft
I am having trouble understanding how to lubricate the intermediate steering shaft on my 1999 Ford Ranger, 3.0 litre, 2 WD, Automatic transmission, Rack and Pinion steering. I was told there is a slip joint in the intermediate steering shaft, and that I should remove one of the pinch bolts, lubricate the shaft, and slide it in and out. I can only find one pinch bolt and that is right above the steering rack, under the boot of the steering shaft. I am confused, do I take out the pinch bolt I mentioned and pull up and down on the shaft going into the rack?
The reason I am trying to lubricate the intermediate steering shaft is because I have clunking noise after the truck gets hot, and it was suggested that the shaft might need lubricating.
1999, 2004, 94, change, expedition, f150, ford, grease, intermediate, lubricating, lubrication, ranger, rod, shaft, steering, thunderbird
