Need Help!!!!
I have a 1999 Ranger and it seems to be stuck in Limp gear. I can shift in and out of drive, reverse, nutral, etc, but it will not shift through any gears while in drive. Its like stuck in first gear or something.
Any suggestions????? Thanks |
RE: Need Help!!!!
It was the wheel speed sensor on the punkin
RE: Need Help!!!!
woulda never suspected that to cause your shifting problem
RE: Need Help!!!!
Usually the speed sensor will cause 'harsh' shifts and the shift 'timing' will be off, sometimes pretty far extended out as well, but should have been able to shift throughout the gear range/s even if a forced drive cycle..
