P0300 P0301 P0305 Code Reader
Old 12-29-2018, 01:28 PM
colorfulpoet's Avatar
Default P0300 P0301 P0305 Code Reader
I have 2006 Ford Ranger manual 4 x 4 sport, with 160,000 km (100,000 miles) that I bought back in August. It had brand new spark plugs and wires done recently. It ran well until yesterday. I drove a few blocks when I noticed when I accelerated there was little power, and it was idling rough. I drove it back home and noticed there was this black soot coming out of the exhaust. I had a friend who borrowed a code reader and it showed the codes P0300 P0301 P0305. I don't have a lot of money, so want to have a little knowledge of what it could possibly be before I take it to a shop.
Old 04-05-2019, 12:31 PM
David Woolard's Avatar
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0305 Cylinder 5 Misfire Detected
A random misfire code usually means the air/fuel mixture is running lean. But the cause might be anything from a hard-to-find vacuum leak to dirty fuel injectors, low fuel pressure, a weak ignition coil, bad plug wires, or compression problems. Even a dirty MAF sensor can cause a lean code and/or misfire to occur.
Old 04-22-2019, 04:40 AM
raski's Avatar
Since this happened a few months ago, can you update us if you fixed it?
whover
08-02-2019 02:49 PM
DanNeedsHelp
03-28-2015 08:07 PM
3tbell@gmail.com
12-09-2013 04:46 PM
Shipwright
06-01-2013 01:31 PM
umoms
02-02-2013 10:30 AM
Quick Reply: P0300 P0301 P0305 Code Reader
