propane ranger
Old Aug 15, 2007 | 08:20 PM
RichardKCMo's Avatar
Default propane ranger
I asked this about a month ago no replys, i'll try again.
Has anyone here had a 96ranger 4 cyl.on propane and knows what parts are needed? thanks
Richard
Old Aug 26, 2007 | 06:30 PM
Default RE: propane ranger
I didn't know there was so much nothingness here, you have a good day.
Old Aug 30, 2007 | 10:07 AM
FordNutz's Avatar
Heard of people making their own lawn mowers run on propane, but I'd search the web and maybe you'll find a kit somewhere.
Old Jan 28, 2008 | 08:54 PM
94RangerXLT's Avatar
i know of a website that makes multiple propane kits but they say not to use them on streets plus if you have emissions testing it will not pass but the site is http://www.gotpropane.com/p4.html
Old Jan 29, 2008 | 08:44 AM
Use Common Sense's Avatar
Have you thought about CNG instead of propane? If so, then here is some info to get you started.
Starting in 2007, Ford made the Ranger pickup available with a natural gas option in BRAZIL. The vehicle uses a fifth generation system with sequential multi-point injection. Some changes in the 2.3 litre 16 valve engine were madeto improve performance on natural gas. The air flow to the cylinders has been increased and the valves have been changed to more durable types. With these modifications, Ford believes the engine life, working with natural gas becomes very similar to a gasoline engine. The natural gas kit is managed by an electronic gas module, working in conjunction with the original engine module. Starting is carried out with gasoline, regardless of the position of the manual fuel selection switch. The turnover to natural gas only occurs when the engine is at the ideal operating temperature. The conversion kit, yes kit takes about 5 days to install. So if you have a friend in Brazil, you may be able to get some part numbers for the kit.
falcans
Jul 8, 2013 04:56 AM
Dutchman
May 26, 2008 09:11 AM
RichardKCMo
Aug 24, 2007 08:37 AM
RichardKCMo
Jun 28, 2007 05:31 PM
Tempestv
May 17, 2005 02:54 PM
