ranger 1989 idle-problem
Old Apr 21, 2006 | 01:44 PM
clms's Avatar
Default ranger 1989 idle-problem
Hello! I have a Ford Ranger 2,9L V6 from 1989. When i start the engine when its cold it runs smooth and steady with a little higher rpm. When it gets warm it idles att a lower rpm ( of course) but the idle isnt steady and smooth, it goes up and down in the rpm, and sometimes its almost stops for a second.. Do you understand me? excuse my english, im from sweden and doesnt type in english so much..
Does anyone have some ideas what it could be?
Greatful for answers!
//clms from sweden
Old Apr 21, 2006 | 06:01 PM
CoyoteRoede's Avatar
Default RE: ranger 1989 idle-problem
sounds like maybe you got a plug problem or your not getting fuel to the motor when it gets warm. try changin the plugs, wires, and airfilter. i did that with my truck and it idles 10 times better than it did.
Old Apr 21, 2006 | 06:25 PM
clms's Avatar
OK, i will try that! I'll guess that this havent been done in a while!.. might as well change fuelfilter at the same time..
thanks for the respons!
Old May 20, 2006 | 09:39 PM
jdm's Avatar
jdm
if that doesn't work try the throttle positions sensor, or just a guess it could be the fuel pump?
Old May 20, 2006 | 11:52 PM
drw0392's Avatar
I had a similar problem in my 90 Ranger, turned out that a vaccum line had fallen off. I'd check all of your vaccum lines before you spend money on any thing.
berniemack
Apr 2, 2009 10:58 AM
damien256
Jan 28, 2009 09:03 PM
rwl123
Dec 8, 2006 12:42 AM
rwl123
Nov 24, 2006 02:08 PM
frankcastle
Apr 30, 2005 04:29 AM
