Replacing timing belt
Help!! I am attempting to replace timing belt, with a Haynes manual....... it is not very thorogh.. I need to know if the bolt that hold the crankshaft pulley on is left or right hand thread. I cannot get it to move either way, I would like to know which way is correct when I get more "persuasive" with it..[:@]
Yes, this is a right hand thread, it is tourqued to around 130 ft lbs. On mine I had to put a bar in the transmission, and used a 1 1/2 foot breaker bar with a 2ft pipe on it to get it loose, Then tap lightly on the Balancecer to get if off.
I hope this helps.......
NickTurbo
Apr 1, 2012 09:21 AM
