squeaky brakes
i have a 2001 ford ranger. my breaks squeaked had right rotor replaces left turned and still squeaked. my dad and i put new high grade pads on stoped squeaking then i took it for a nother drive and when i press on the pedal fairly light the squeak.. as iff its every time the wheel turns over. i think the new pads just have to seat.. if its not im out of ideas please help!
RE: squeaky brakes
just a thought! my truck had a similar problem some time ago! the rotors were good and the brakes were good but i changed them anyway and the problem still persisted. so upon closer examination i found that the low brakes metal strip indicator ( which made it sqeal when i used the brakes) was jamed against the caliper and every time i hit the brakes this strip would also make contact making noise. so with pair of pliers i bent it back some so it would be off the rotor and problem went away.
| All times are GMT -5. The time now is 05:46 AM. |
