-   Ford Ranger (https://www.fordforum.com/forum/ford-ranger-16/)
-   -   Starting problem on a 93 Ranger (https://www.fordforum.com/forum/ford-ranger-16/starting-problem-93-ranger-18229/)
dankhar Sep 18, 2009 04:48 PM
I am needing some help with a 1993 Ford Ranger XLT.
At the moment, the truck turns over but does not start. The spark plugs are not fireing, any ideas?
Thanks in advance for the help.
~Drew~
xzuatl Sep 19, 2009 09:55 AM
It could be a number of things. The engine needs gas, air, and spark (battery) to start. It sounds like your starter is turning. So... Do you hear the fuel pump charge the ssytem when you turn the key before actually trying to start the engine? Are you getting pressure in the fuel line? If you spray starter fluid in the intake does it run then cut off?
dankhar Sep 20, 2009 08:46 PM
Yes, everything else is working but the spark plugs.
FIRE RANGER Sep 23, 2009 05:17 AM
Have your coil packs and control module tested, auto zone and murrays does this for free.
Cindy G Aug 28, 2013 10:28 PM
88 Ranger 2.3 won't start
I'm having similar problems with my 88 Ranger 4cylinder 2.3L. Changed Cap, Rotor, Spark plugs & Wires, Coil, and today the Module, getting spark now but still won't start and now it has black/grey smoke coming from the engine, any ideas.....Is it dead !!
GilbertF Aug 29, 2013 05:59 AM
Could be a fuel problem.
Do you always have spark? If you always have spark at the plugs, then the ignition system is probably ok.
If so, then rent a fuel pressure gauge from any Autozone. With that in mind, check your fuel pressure and tell us what it is.
Check the link below in autolibrary that I have for fuel pressure specs, etc.
Clean the mass airflow sensor with electrical contact cleaner. It could be dirty from that off road driving.
hanky Aug 29, 2013 09:41 AM
Something you can check,
now that the engine will at least start and run, remove one or two plugs form different cylinders and look at what they show. If very wet and black either there is an overfueling issue or the cylinders were flooded with so much fuel it takes a short while to clear the cylinders / plugs.
Did you have this problem before changing all the above parts or did the problem come up after changing the parts?
