01 taurus has po301 code.. still dont know?????
I have a 01 taurus that I got from Homeland Security out of El Paso Texas.
When the weather started to turn colder we started having problems. The check Engine light came on and she started to idle rough. This is a list of what we have done or fixed 1. All new spark plugs and wires. 2. New PCV valve 3. Remover and cleaned the Mass Air flow Sensor and new Air flow filter 4. Used Sea Foam in the gas 5. Replaced the belt 6. oil change After replacing all these things, she is running much better, but we are still getting the same PO301 code. My question is..... Could the Ignition coil be going bad? Anyone who can help. please!!!:confused: update:.... I just replaced the ignition coil... she is running rougher than before... my husband took the ignition wire off the ignition coil on cylinder #1 and it shocked the crap out of him BUT there was no change in her idling.... she stayed the same..... OH BY THE WAY..... once she gets warmed up, she runs fine and acts just fine. My mechanic cant figure it out.... PLEASE HELP!!!! |
P0301 says misfire on Cylinder 1. The prime suspects are plugs wires and coil. But a misfire could also be cause by a bad injector or an intake manifold leak, or even a loss of compression.
I agree with bluewind. Also a problem in the valves could cause it.
The only things we have not looked at are the injectors and the intake manifold. We are about to replace the spark plug AGAIN!! the guy that put it in.... well lets just say, I'm not going back to him again. Any other ideas or suggestions:eek:??
Does anyone know a good link to the air intake system on a 3.0 01 taurus?????
I just changed the spark plug in cylinder #1 again and she has more power but still alittle rough. Thinking it may be a hose that needs replaced... Need a link so i can find out for sure! Please help!!!!!! |
Here is a link to the Ford parts breakdown. Click o0n thye air filter pictureGood luck.
Buy 2001 Ford Taurus Parts | FordParts.com |
fresh gas?
thank you so much!!! Ill let you know what happens....
Now what exactly did this Sasquatch do to your plugs, in particular No 1?
Originally Posted by Purplekangaroo1
(Post 76058)
he used a pair of pliers to put the plug in. we replaced it with a second new plug on Saturday. the check engine light came back on this morning but is not flashing, just solid.
| All times are GMT -5. The time now is 06:25 AM. |
