-   Ford Taurus (https://www.fordforum.com/forum/ford-taurus-26/)
-   -   02 Taurus Lower control Arm (https://www.fordforum.com/forum/ford-taurus-26/02-taurus-lower-control-arm-24998/)
charliechicken Aug 10, 2011 10:14 PM
Hello,frustrated as can be,went to change the bushings as per topic,had all bolts out,lower arm was loose,however could not get it out,the front bushing would not pull out. Question do i have to remove rotor and take strut out to move the arm up higher to pull it out,frustrated put it all back together hope someone has done this two bolts and a ball joint figured it should just pull out,feels like the forward bushing is caught inside thanks for you time CC
