07 Taurus heater/AC blows only hot air all settings
3 days ago the heater/AC only blew cool air on all settings for a day -now all settings -heat and A/C blow only hot air.
Check to make sure that your "BLEND" door is working. It may be broke or stuck in the HEAT position. Check for a vacuum leak or a loose vacuum line under the dash or on your control panel.
