1999 Taurus Horn
Hi everyone!
Im working on a 99 Taurus that has a bad clockspring in the steering wheel, and therefore the horn/airbag/cruise control won't work. Instead of dealing with taking that apart, I bought a aftermarket horn button from Oreiley's and would like to wire that in. I went off of Bulldog Security's website to locate which wire I would need to hook the button up to in order to activate the factory horn relay. It said it is a purple/orange wire thats in the 4 wire plug to the right of the steering column. I see no such wire. There is a solid purple one on one side of that plug, but then it goes into a solid blue one on the other side. So if anyone could tell me which wire it is that activates the horn relay, or if someone could post a complete wiring diagram of the horn circuit, I would greatly appreciate it. Otherwise I will have to run a wire directly from the button to the actual horn and just bypass the factory relay/circuit. Thanks alot for anyone's help! |
1 Attachment(s)
