2000 taurus 3.0l 24v engine diagram
I was hoping that someone out there may have a diagram of a 3.0L 24 valve duratec engine.
What diagram? Probably have a lot of different ones. Specify what area you want.
Sorry about that!!!
I want to change out the thermostat. Where is it located? ThX |
2 Attachment(s)
Thermostat — 3.0L 4V
Removal and Installation Drain the engine cooling system. Disconnect the lower radiator hose from the water outlet adapter. (first thumbnail here) Remove the bolts, the water outlet adapter and thermostat. Remove and discard the O-ring seal. (Second thumbnail here) To install, reverse the removal procedure. |
Cheers way2old I'm right there with ya!
Thanks |
Similar issue but different
I own a 2001 Taurus Duratec and the above diagram does not look like my configuration. I'm having a hard time finding the part that gets bolted onto the Thermostat housing. Help?
Ken 2001 SES 275,000+ |
| All times are GMT -5. The time now is 01:14 AM. |
