2000 Taurus Duratec #3 misfire P0302 ... Help
Old Jan 6, 2008 | 11:27 AM
Tuarus_2000's Avatar
Default 2000 Taurus Duratec #3 misfire P0302 ... Help
I checked it with my scanner it says P0302 #3 misfire ... I have replaced the elbo for the PCV a while back it was split (common problem) and replaced DPFE a while back for other problems and it fixed those.
Now today I was at a stop light felt a stumble, left it running while I ran into the gas station and came out its still running and engine light is steady on, tried to pull out it feels like hardly any power and a rumble strip type of feeling, once at speed it would sort of power up normal and then feel like no power again stumble and such, came home checked it and code P0302 came up (no other codes at all).
Is this a common problem? ... I also changed the spark plugs about 10k miles ago ... any info on what to check would be great, and where is #3 cylinder on my car. Thanks!
Its a 24 valve Duratec 2000 Taurus 125k miles
Old Jan 6, 2008 | 12:00 PM
way2old's Avatar
Default RE: 2000 Taurus Duratec #3 misfire P0302 ... Help
Well, first you need to address the problem cylinder. It is a misfire on number 2 cylinder. Number 2 cylinder is the rear center spark plug.Click here for a diagram.
Can't get pic to post for some reason
Old Jan 6, 2008 | 12:29 PM
Ok got that, #2 I was wrong on that ...thanks for telling me on that.
I have coil on plug ... I have a good volt meter is there a way to check the coil on plug ??
Also a way to check injector?
I am also going to get a new plug perhaps its bad.
Old Jan 6, 2008 | 06:15 PM
way2old's Avatar
You can use a test light on the coil connection to see if the test light flashes consistently. If it does, you need to get a spark tester and test the coil in question to see if there is a bright blue spark. If not, replace coil. You can also look at the coil boot to be sure there is not a small burn mark through it.
Old Jan 7, 2008 | 09:04 AM
Use Common Sense's Avatar
Any moisture in the plug area? Did you use any dielectrical grease on the plug boots when you replaced the plugs? Moisture and no dielectrical grease can cause spark leakage, thus the misfire. This occurs more after the engine warms up as the boot expands due to the heat allowing more leakage to occur. I see this all the time. Especially on higher mileage vehicleswith original plug wires. Since we use Coil-On-Plug/Boot units, the dielectrical grease is a must. I also put some where the boot meets the valve cover.
Old Apr 8, 2008 | 06:31 PM
hakies1228's Avatar
don't shoot the messenger, but i have (what sounds like) a smiliar issue on my 2000 sel, however my car puts out thecyl 3 (front center)code. i got the car for a song, knowing the check engine light was on. while at idle, does your light flash for 30-60 seconds?? my car spent a week in at a mechanic and all signs lead to a bad (bent or chipped) valve or possible crack in the head. have your compression checked. with 173,000 miles i am not going to spend the money to repair it. i had the coil replaced (with a motorcraft unit) as well as the injectors cleaned, all 6 plugs were replaced, and thevalve cover was pulled to inspect.the compression is lower in cyl 3 than the others in the front. sorry for what may be bad news, but that is where i am having the problem.
Old Jul 10, 2014 | 10:15 PM
Mark Stambaugh's Avatar
i have a 2000 ford taurus with the 3.0 v.6 engine and it has a bad misfire the code tester says 2 codes cylinders 1and 2 misfire. i changed plugs and wires but still nothing. can u tell me whats wrong please?
Old Jul 11, 2014 | 06:11 AM
Since you didn't specify which 3.0 and you changed the "wires", I have to assume that you have the 3.0 Vulcan engine with a coil pack. For what it costs ($35-80), I would replace the coil pack. Especially being 14 years old and who knows how many miles. Don't forget the dielectrical grease to eliminate any possibility of spark leakage.
scotttss
Jun 4, 2012 05:11 PM
readcit
Dec 12, 2010 11:27 AM
anne1976
Mar 17, 2009 04:04 AM
jerry stastny ford
Oct 31, 2006 03:43 PM
jerry stastny ford
Oct 30, 2006 07:48 PM
