2003 starting problem
when engine is cold starts and runs fine , drive it for 15-20 min runs great shut it off try to start it back up just clicks let it cool down starts right up over and over drive it get it warm will not start just clicks. im thinking starter gets warm will not start not sure why any one with same problem or info?? 2003 ford tarus 3.0 v6 73k
RE: 2003 starting problem
[sm=welcomesign.gif][hr]I would check and clean the battery termanals and the battery wire's to the relay and the starter for corrosion.[hr]Then if you still have a problem start by changing the starter relay.
