2003 Taurus 24V
My 2003 Taurus has been running erratic after short stops. I will drive it somewhere for a while, shut it off and try to start 5 minutes or so later and it will not idle correctly. If I give it a while, shut it off and it will run fine
Any Suggestions
Any Suggestions
I'd check for troublecodes, around my area, Autozone will check codes for free.
The IAC system can cause idle issues, I wouldn't replace without doing some testing. A comtaminated maf sensor can cause idle issues. There are several possible causes.
