| hanky |
Feb 10, 2013 03:26 PM |
If I may, you guys are talking two different languages.
So everybody is on the same page, the part with the timing marks on it is called the crankshaft pulley or vibration damper. The cam parts are entirely different.
I think what Grindman is asking you to do involves using the key and starter to turn over the engine so you can feel the pressure coming out of the #1 plug hole. You need to notice the direction of normal rotation when cranking so you can complete the rise of the #1 piston to top dead center. You need to disable either the spark or the fuel so the engine won't start on you when feeling for the pressure increase. That #1 hole can be a dog to get to to this depends how much junk is in the way. To prevent any addl codes from coming up , what I do is ; find the inertia switch and while the engine is running rap that switch so it trips and the fuel pump stops and the engine runs out of gas. Crank it a few more times , now you can remove the plug and crank the engine and it shouldn't start . Just don't forget to reset the inertia switch when done or the fuel pump will not work.
The rest is yours Grindman, and I hope You didn't mind my notes.
