-   Ford Taurus (https://www.fordforum.com/forum/ford-taurus-26/)
-   -   2013 Taurus Question (https://www.fordforum.com/forum/ford-taurus-26/2013-taurus-question-35800/)
Haw1936 03-28-2017 02:54 PM
I have a 2013 Taurus Limited. Great car! Enjoy the backup feature. Great gas mileage. Super pickup. Beautiful looking car and get compliments on it. Here comes the dropping boot! I have turned the lighting up as high as it will go for the dash, but the speedometer, 85% of the time, is invisible. I can't make out the speed. I am wondering if a light has burned out, if such exists?? If it does exist, where is its location and how difficult is it to replace?
pfmerlino 12-20-2018 01:54 PM
I just posted a similar problem with my Taurus. The speedometer dims at night or in an indoor garage when it should be the brightest. I cant get an answer for this issue.
Hayapower 12-29-2018 12:21 PM
The panel dimming is a normal feature for over brite/ glare in low light conditions.
pfmerlino 12-31-2018 08:05 AM
I just cant understand that a dimming feature is normal under low light conditions. To me it should be the opposite.
Hayapower 12-31-2018 09:32 AM
Some/later MY’s your able to cancel auto panel dimming through the Message Center.
When dimmed, can you manually overide the dimming feature with the panel dimmer control?
pfmerlino 12-31-2018 10:12 AM
I have turned off the auto dimming option to no avail.
Hayapower 12-31-2018 10:23 AM
If in dimmed mode, can you manually raise lamp output over the programmed level using the dimmer buttons?
pfmerlino 12-31-2018 10:29 AM
The dimmer button is at it's highest level at all times. Any higher and the dome lights activate.
Hayapower 12-31-2018 01:04 PM
PM sent
Hayapower 12-31-2018 02:22 PM
With the lamps in manual mode, the auto backlight dimming HL ops should be canceled
