-   Ford Taurus (https://www.fordforum.com/forum/ford-taurus-26/)
-   -   93 taurus fuel pump (https://www.fordforum.com/forum/ford-taurus-26/93-taurus-fuel-pump-18963/)
mcs58 Dec 26, 2009 09:49 AM
93 taurus fuel pump
Hi I am usually in the truck forum 87-96 is there any way to replace the fuel pump by going thru the floor or whatever without dropping the tank? 93 taurus
way2old Dec 27, 2009 03:24 PM
The correct way is to drop the tank. If it is low enough on gas, you can just lower the back and remove the pump. If you cut a hole in the trunk, you can access the pump, but it is really hard to move the connectors out of the way so you can remove the pump. I would bite the bullet and drop the tank. It can be replaced in about an hour lying on your back.
mcs58 Dec 28, 2009 07:06 AM
93 taurus
Thanks for the info, I guess that is what I'll do good thing is the garage has heat 18 degrees this morning
