fritz346 |
11-04-2009 11:14 AM |
95 Ford Taurus Rear Disc Brake Ploblem
I have replaced rear caliper, rotor etc. Bleed brakes, one side locks for me the other side will not engage, can still turn wheel with brakes applied. There was some fluid coming from line when bleeding, also when bleeding pedal would go right to floor, then come up but then right to floor again. I did replace a brake line that i saw leaking. Extra info, this car needs brakes done about every 4-6 mths. only one side gets hot and wears down, we usually take it in to garage to have done but with the problem occuring so many times thought we would do ourselves this time around
