97 taurus got code P1131???
Old Feb 25, 2008 | 07:30 PM
hermtm2's Avatar
Default 97 taurus got code P1131???
Hi.
I have a 97 taurus which is 140k on it. It shows an error code p1131. What I found is "Lack of HO2S switch - sensor indicates lean". What is that mean? Do I have to replace the O2 sensor to fix the problem? Or anything wrong? Would you explain to me?
Thanks.
Old Feb 26, 2008 | 07:47 AM
Use Common Sense's Avatar
Default RE: 97 taurus got code P1131???
It's possible that the O2 sensor is bad being is a 97with140K miles on it. The P1131 code is "Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 1". Double check the connector for clean contactsince bank #1 gets all the salt, slush and road crud.
Old Feb 26, 2008 | 08:54 AM
hermtm2's Avatar
I will check it up first.
Thanks.
kennyjulie79
Apr 21, 2013 11:21 AM
Tucker
Feb 2, 2009 03:36 PM
Tucker
Feb 2, 2009 03:25 PM
idogdou
Jan 18, 2009 07:05 PM
mar7
Nov 12, 2008 09:04 PM
