99 3.0 taurus dies as soon as you put it in gear
replaced both motor mounts still dies as soon as its in gear pleas help:(stumped
RE: 99 3.0 taurus dies as soon as you put it in gear
If you 'slightly' raise the RPM with the accell. pedal, and then go into gear, does it still stumble/die? Or, can you raise the idle, go into gear with ahigher idle then slowly release the throttle without it dieing, with just a slower than spec idle?.
Anyone with any additional input? Mine does the same thing If i start the car up from a cold start condition, It runs fine but when i stop and place the shifter into park the engine dies immediately. If i try to restart the engine just turns, But no start, After a few minutes the engine will start but as soon as iplace it in gear it shuts off? After about ten minutes the engine starts and the car runs fine.
same here. the issue is right after i put it in gear. and it only does it when its warm. if i let the car idle a few minutes then put it in gear it works.
