-   Ford Taurus (https://www.fordforum.com/forum/ford-taurus-26/)
-   -   Acceleration Issue (https://www.fordforum.com/forum/ford-taurus-26/acceleration-issue-11705/)
golferguy Feb 2, 2008 10:57 AM
Acceleration Issue
Good day all! I've got a 2000 Taurus with about 125K. Over the last couple of weeks, I've noticed that when I climb a large hill (daily)with cruise set at 55/60 the car has a "mushy or miss" accelaration. Also, after I feel it the rpms increase to meet the demand of the climbthe "mushy/miss" acceleration is gone. It reurns when the rpms level out again. Today I encountered it again and half way up thye hill, the check engine light started flashing and keptflashing until I leveled out. Went out ans stayed out for the rest of the trip. Otherwise, the car works as advertised. Recent maint: oil change, fuel filter, egr/pcv valve/sensor.
I'm not the sharpest bulb on the tree but could it be the plugs/wires or transmission slipping. I'm not the first owner so I don't know if there was a tuneup done.
Any point in the right direction is appreciated.
Golferguy
TOMMY D Feb 2, 2008 02:04 PM
RE: Acceleration Issue
check your vacum lines to see if one is bad or put a vac gauge on and check vac. kinda sounds like a possible bad vac.
Mulletman Feb 3, 2008 09:09 AM
If the CEL came on and was flashing, there is a code stored. Get a scan and post the codes here.
