-   Ford Taurus (https://www.fordforum.com/forum/ford-taurus-26/)
-   -   check engine light wont go out (https://www.fordforum.com/forum/ford-taurus-26/check-engine-light-wont-go-out-24273/)
lou40 May 4, 2011 04:56 PM
2000 taurus
i have codes p1443 and p0457
not the gas cap like everyone said. any other ideas.
way2old May 4, 2011 06:06 PM
You have a small evaporative system leak. The leak is less than .020 inch leak. You probably need to check to see if there is any debris in the vent line off the evap cannister. If that is cklear, you probably need to have it "smoke" tested.
lou40 May 5, 2011 08:26 AM
check engine light
thanks I will check. when people say canister they mean the square unit behind the tank under the trunk??
way2old May 5, 2011 06:51 PM
Right
